That body tag was applied at the assembly plant, and I am not certain where the car was assembled before it was sent to Pinner for the conversion.  When I first went to look at the car, the tag was missing.  When I picked it up, it was miraculously found inside a repair manual.  The Doctor who owned the car told me that the "mechanic" who worked on the car for him removed it to take to the auto parts dealer when he needed repair items.  He wasn't willing to give the book to me, saying that he had to return it to the mechanic.  He also removed some other trophies from the car, such as the dedication plaque that was originally on the right side of the roof.  I believe that Nick eventually got everything from him that was removed from the car.  The only thing that I have that I know of is the Reeves Stretcher that I have in my 1962 Chevrolet.
The car was in terrible mechanical condition, and whoever the mechanic was who worked on it lacked significant experience with repairing cars of that vintage.  He literally destroyed the rear axle, attempting to remove it to repair the brakes.  I was fortunate to find a complete rear-end assembly at a local salvage yard, and with the assistance of Sandy, we successfully installed it, replaced all the brake wheel cylinders, new brake linings, and hoses.  Even after being repaired, where Pinner cut the body for the stretch and cut the brake line, extending it with copper tubing, ferrules, and compression nuts.  I performed a mid-section replacement of the brake line and replaced everything from that point rearward with the correct materials and double flares. I also had to do the front brakes, replace the power brake booster with the correct one, and rebuild the master cylinder.  When I removed the water pump, I found that it was the cause of the car's overheating.  The impeller had become loose on the shaft, and even though the shaft was turning, the impeller wasn't.  I don't believe that there was any mechanical part on that car that wasn't either rebuilt or replaced, with the exception of the engine and transmission.  Both of those required resealing, and I handled the engine, while a friend who used to work for a Chrysler dealer took care of the transmission.  I have no idea what parts were needed for the resealing and reconditioning of the transmission.  I only remember that it was very costly for parts and labor.  I spent many hours looking for New Old Stock parts for that car, since I wanted it to be reliable for the trip to the International Meet in Flint.  The car made the trip without any issues and returned home again.  I believe the round trip was approximately 3,200 miles.  At the time, I had a Christopher Columbus GPS.  It took you around the world and got you lost many times.  That trip convinced me to use a Rand McNally atlas to map out the route and use the GPS as a backup.
