Had a couple tasks today needed to get the white painted on the rear door jam and the red on the in side of that Center door. So we can be ready to go back on when i get the jam cleaned up. Started on the top for the door it was that or the jam. The top went better then i thought it would but we found some rust under the weather strip. It was bad enough we coated it with converter. Found one of the sash strips is rusted out on the bottom so we will need to replace it. We can get this primed tomarrow after the converter has had time to work.
