Productive week. I actually achieved my 3 goals this week.
Goal #1
First I reinstalled the passenger side loading door window. I took the window seal off the window. I started by cleaning the window seal with soap and water and removing as much of the dried sealant as possible. Next, I used the pressure washer to remove any loose sealant that I missed, and finally, I went with a pick tool to remove dried sealant leftover on the inside of the window seal. Before reinstalling the window, I scrubbed the metal where the window sits, treated it with rust converter, and painted it with rust paint. There was only minimal rust in that area, but since it was exposed, why not. I replaced the old strip of wood that sits between the door and the bottom of the window with a 1/4" plywood strip that I treated with wood sealant in case it gets wet. Finally, I polished the interior window trim and made sure I had all of the pieces lined up and ready for the install.
I applied fresh urethane to the inside of the window seal and to the areas of the door that are in contact with the window seal. Looks good and as a bonus, I did not get the urethane all over myself, the window, or the car.
Goal #2
The second thing I wanted to do was to replace the vinyl inserts located above the rear loading door, on the side of the car, and down the A posts. I got 100' of black vinyl insert from the local RV store earlier this week and installed that today. It is a small detail, but it makes the car look smarter.
Goal #3
Finally, I wanted to see what the Vinyl lettering looked like on the car. I watched a couple of YouTube videos on how to apply decals to a car and voila, done!!
It will have to be done over, my vinyl decals skills are, let's say not up to par. There are quite a few bubbles I could not get to go away. The original letters were a little bigger, but I think that this will do just fine. When I get the Star of Life I'll get the sign shop to install the decals for me.
Lastly, I received the pyramid shape rubberized floor mats. I have put it aside for when I tackle the interior.
