A little bit of this, a little bit of that kinda day.
Following Ed's recommendations, I taped up the bumper ends and sprayed a generous coat of silver rust paint. I'll wipe down the exterior with paint thinner tomorrow. Hopefully, this will be the end of this part of the project.
I also received a sample of the rubberized pyramid flooring material. I am happy to say that it is a perfect match. I figure that I should have enough of 15 feet x 3 feet to replace the material currently in place. I'll order a little more just in case.
Lastly, I removed the Motorola radio that was in the car. The plan is to replace it with a GE radio and add a CB like the original car. If anyone is looking for one of these radios, let me know, I do not need it.
As you can see from the picture of where the Motorola was, the status lights used to be in a vertical position. the hole to the bottom right of the original status lights is for the tachometer that was moved to the left of the steering wheel just beside the fast idle handle. My guess is that the tachometer was used to set the high idle to a specific RPM. More things to move around when I get there.
If anyone knows where I can get a clean piece of dash to replace the one where the status lights are that would be appreciated. It would be nice to have a clean piece there without all of the holes.
View attachment 47909View attachment 47910View attachment 47911View attachment 47912View attachment 47913View attachment 47914View attachment 47916View attachment 47915
