If what you have is now working leave it alone for now. They changer the exciter wire harness. what you have will not go on the older one. You also have no ida if the regulator works or not. Play around a little first. Find the plug you need and the wire harness is all there. Half the time they cut off the battery wire that should go between the ault and the regulater. Mean time all you need is the one wire going to the plus side of the battery to get it to charge. They are a pain to swap were they are. Make sure you have what is needed before you start.
