Well yesterday I took my 5 year old son in the hearse with me to drop a bunch of bags of old clothes off at goodwill and get some groceries. As luck would have it as soon as I pull into the driveway the car stalls and will not start again. I say luck because I feel fortunate that this occured in my driveway as opposed to the road.
 It was a warm day so I thought maybe it was vaporlock, waited half an hour and came out and same problem. At once point it did start for a few seconds and sputtered out again. Made sure I didnt leak fuel anywhere and that it indeed had gas. No luck.
I had things to do so I decided to just let it sit until morning and try again. I didnt like leaving it diagonal on my driveway but at least it wasnt in the street. This morning I went out and gave it FIVE good long slow pumps then got it fired up, I quickly moved it the rest of the way up the driveway before it stalled again. Seems I have very low fuel pressure as 5 pumps was just enough to start it, but its not moving gas quick enough to stay running.
I'm probably going to take a look at the filter first, maybe put a jar under and turn the key on to see if anything is fed into the jar or not. If fuel is getting to the filter then I'd assume the pump is fine. If thats the case then maybe the carb filter is culprit.
I just hope I can get it sorted soon, because I already registered for a car show June 8th and was looking forward to that. At least I have a plan though
