Don't get froggy on it.  Did you find the vacuum leak?
Go to ebay get you a owners manual if you font have one and a shop manual. They will help you.
Most times, the plugs are properly gapped right out of the box. If you are going to be removing the plugs, you might as well just replace them all, since new plugs aren't that expensive. There is a better chance that the plug wires are defective than the plugs themselves. Also, the "dwell" of the ignition points should be checked, and the timing properly set.
Gap on new plug looks wrong what do you think Ed?
Putting the grease on the threads is not necessary. What you are experiencing is setting problems. Carbon build in with short runs. The sea foam has helped to pass it threw the systen. Drive it, thats what it needs. Not long idle time but a trip out were you can get it up to speed for some time.
