I still have a 6 volt siren light and a 17 to go with it.
Thanks Ed. Yes, I have been using a 9 inch disc with 40 grit on the larger areas. Man...that sure cuts down on the time. I learned that you need to switch back to a smaller sander with 80 when you're closer to the leaded areas. I'm definitely going with the elctronic points.A little 36 grit on the 9 inch sander will have that down to shining steel in half a day. One other hint if you put in the pertronicks solid state points she will start and run a lot better. They do make one in 6 volts for that engine.
Thanks Ed. I sourced both of those early on. A nice double tone with a Propello-ray in fact. Does you 17 have a plastic or glass dome?I still have a 6 volt siren light and a 17 to go with it.
If you were not brave or naive, the Pontiac would still be parked waiting for you to start the work.Brave or naive perhaps. In any event, it's a learning journey for me and I'm enjoying doing the work I'm capable of.
