You'll get there ablut the time you are done.
It is all a learning experienceThe oil base primer can't handle the laquair base undercoating. Funny thing is you could do it the other way around and be Ok.
It's on the list for next year as well as taking the radiator at the end of the hoses to the radiator shop to get it tested.Are you going to be replacing the rubber hoses as long as you are in there? Now is the time to do this before they leak.
I still have to take a good look at the heating system for the patient's compartment, but for added safety, I will also install a second shut-off valve to the lines so that I can turn off the water flow in both directions.Are you going to be replacing the rubber hoses as long as you are in there? Now is the time to do this before they leak.
