Warm up transmission
I had a thought last night as I was going to sleep. I know that back when I had a shop working on this I had them tie the choke fully open.
I was entertaining a "what if" scenario in my head last night and thought "what if" as I increase the thottle the choke plate is falling down to the closed position until I back off the gas and press it again to raise it back open?
I recall them telling me the auto-choke wasnt working, and when it was zip tied it simply wouldnt run. BUT I'm thinking what if I zip tied the choke, not so its fully open, but only so it cant fully close, say tie it so it can only get 1/4 closed or so.
I figured once I get good and warmed up, I can shut off and apply the ziptie with some slack, then drive around a bit.
This way if my issue changes from complete choking to just a loss of power due to it only partially closing I can isolate for sure if its choke related.
Granted I'm no expert yet with the carb, but its something I was thinking about, this is something I can test first without having to dismantle anything.
If this test is unfruitful then I can take off that switch and have a look (probably want to do that either way though).
Does this make any sense or am I talking nonsense?
You clearly have a carburetor problem, and it is only a guess on my part, however, if the choke isn't working properly, and is flopping around, it needs to be fixed properly. By using the word "it", I am referring to the complete and whole carburetor. Anything less isn't going to result in favorable results. In fact, once you have the carburetor fixed, that doesn't mean that the engine is going to be better at all, since the defective carburetor could be masking other engine issues. You fix that which is an obvious problem first, and if some other issue is then identified, you either fix that one, or do a comprehensive examination of the engine as a whole, and determine how you want to attack the problem or problems. There are 3 things that are needed for a working engine... i.e. Fuel, Air & Combustion. You have a fuel problem, and once you correct that, the air issue will correct itself, since it is infinitely variable by the carburetor. The next is combustion... i.e. Spark plugs, spark plug wires, distributor and its associated parts, and finally, compression of the engine and its associated parts. By this, I am referring to piston rings, valves, cam to crankshaft relationship, etc.. If any of these are a problem, which you can't tell without a comprehensive examination, you will never resolve your problem(s).
You need a good working carburetor no matter what else has to be repaired, so that should be your starting point. It doesn't take a lot of expertise to remove it from the engine, and once repaired, to reinstall it. Many carburetor remanufacturers will do all the preliminary settings, so it should work properly right out of the box. It may require some fine tuning, and you can have that done by a professional once you have the car running properly.
I learned today that apparently many shops believe quadrajets are all the same and part of my problem may be that I have the wrong QJet. I'm going to check the number tonight and see if it matches what is correct, and also run some tests on the choke with it warm.
A paste from the cadillac/lasalle forum:
My thought has been, and is, that you have a carburetor problem. Now that you have mentioned that a "repair shop" put a rebuilt Q-Jet on your engine, I am even more suspicious of the carburetor. GM used Q-jets pretty much across the board on their engines for many years starting in 1967 (on Cadillacs, other GM lines earlier), there are those that think they are all the same (or close enough) that any old replacement Q-Jet will do --- absolutely not so! Do you have any idea if the shop put on a NUMBERS CORRECT replacement Q-Jet for your 1968 Cadillac engine? Every Q-Jet I am familiar with has a number sequence on the carburetor body that identifies the year and division make engine (Cadillac, Olds, Chevy, etc.) that that particular carburetor was designed and calibrated for, as well as what transmission it had. Many Q-Jets may FIT on your engine and work to some extent, but they may well not work properly.
On our older cars, owner knowledge and education is most important! Many shops and so-called mechanics these days are as lost looking at and working on 1968 Cadillac as I would be working on a modern fuel injected engine.
http://www.carburetion.com/quadnumber.htm
Note that it points out at the early Q-Jets up until the early '68 models had a stamped, round disc with identifying numbers attached to the carburetor while all later models had the numbers stamped into the carb body. With your '68 the original carb could have had the separate attached tag OR the numbers stamped into the body. My experience with Q-Jets is that it is often (maybe always) better to have the original one off your engine rebuilt by a good carb overhaul shop --- there are plenty around and many of us here can recommend a good one.
Check the numbers on your present carb using the link I posted above and see what it is really for.
If you feel that your carburetor has incorrect parts in it, then I suggest that you contact a fellow in Arizona that has shelves full of correct carburetor cores that he can rebuild for you. He specializes in the Quadrajet carburetor. Without his permission, I will not post his information on line, however, you can contact me for his contact information.
You could also send him your old one, and have him restore it with correct parts as necessary.
Just keep in mind, not to remove the large fuel nut, because 99% if the people that do, that don't understand that it is a very fine thread, will ruin the threads in the carburetor. That can be a very expensive mistake.
I called him in January and i do plan on using him. I just need to gather the funds. Old carb is in a box ready to go.
This evening i tested if my choke was closing, by using a series of zipties to "block" the plate from fully closing but still allow movement. Drove around the block and issue didnt change. So that rules out the possibility of the choke closing while driving. I removed all the ties afterward
Tomorrow i will try to find and trace wires from the starter.
For that ignition switch i need to figure out if it comes out the bottom or i need to remove the dash panels.
that book off e-bay will help you take this apart and fix them right. it save you more money then it costs. there is a screwed on plate under the steering column. take it off and the universal one is held on by that knurled outer ring. it will drop out the threw that hole you uncovered. caution do one thing at a time don't have a lot of this apart at the same time.
you can read the number off your carb and go to the carb shop web site and see if it is the right one for your car. it should be left hand rear if it's stamped
the one that goes to it is the outside right one it will be ported and that not the dash pot that is the vacuum pull off for the choke. it's function is to crack the chock open when it fires. the dash pot is one the other side it's function is the prevent it from stalling when you return it to idle. once again I tell buy that book. it would look like you have a few things mixed up there. any one set will. give you problems.
You say its the right-most hose? the one that is on top of the other? I just want to make sure because my initial though was it was the lower one, the left one.
not doubting you, I just want to make sure I understand you correctly.
That book is on my list. I am going to buy a copy very soon.
When you get it look things up. The far right port. Right on a car is passengers side no matter were you are standing or direction you are looking. Wondering what they plugged it into? Each one of those ports went some were. One of the problems with the rebuilt is some times you get a body that has more ports then you need.your to cap them off. If the people that replaced that carb didn't know enough to hook the choke pull off what else did they miss? Had you gotten the book most of this would have been behind you.
Looks like they had already put a T connector on and put a hose there, but instead of connecting it they tucked it down between the carb body and the other hose so it wasnt in the way...
I had thought that other hose was connected to something but no, it was loose.
I connected it yesterday and no change in how it runs though. I'll keep going down my list. I have about 20 minutes to a half hour every day to work on it.
I was doing some thinking and I was thinking about how when I refuel it seems to run good for a day then after sitting all night, or even all week its back to its old ways again.
With this in mind I thought maybe this is because as I refuel I disturb the existing fuel and it mixes with the new, creating a better, fresher mixture.
Then as it sits the gasoline, water and alcohol separates and next time I run I'm sucking up the bad fuel or some water.
It just seems strange that after my last refuel it ran perfect. I know I should get a few gas canisters and a pump and empty that tank out. That might be on my list this weekend along with looking into the switch and wires
It should not have a t in it but be hooked up by it's self to that port. What ever that other line is going to should be hooked up some were else. What i will pass on to you is one simple thing if you remove all the things that other people did thinking they were improving the car or that it did not matter and put every thing back to the way GM did it the car will run like it did in 68. One of the hardest parts of restoring one is to ID remove and put back right all these changes and suggestions back the way It was engineered it will run decently.
As for the fuel it will take at least 3 mos of setting still for the water to separate from the ETOH. That problem is most likely rust build up plugging the fuel line. You put fresh fuel in it you stir it up it then gets sucked back as you drive it.
You then think the carburetor is at fault so you get some one to swap it. They screw that up and you fight that for a long time mean time the original problem is still there. But now even if you fix that your still fighting what was done before and after to try to do the quick fix on the original problem.
See why someone sold the car or parked it outback for ten years. You get all the mistakes corrected then you correct the the original problem and you have a good car. But do it one thing at a time.
Yeah there were several T's in the vacuum hose configuration. I will try to eliminate the T leading to the break.
I took alot of pictures today. I will post those later. Here is a better pic of the T. Seems it connected right, just lo g and wrapped around.
I also hear hissing from the gas pedal. I found several disconnected items, will post pics later, like i took tons and im on my mobile now
you are missing what I said. the line to to the choke pull off should not have a t in it. it is by it's self. I'm not that up on mechanical working of the 68 Q-jet but t I believe is a ported vacuum source. that means what ever that 3 leg of the t goes to will be shut off at times. here is a pictures of a 69 carb . your pull off should look like this. there is way to much vacuum on that car to guess were this should go or that should go. think book or look up on line for the carb vacuum placement don't play till you have the play book. my guess is that hose is to large, they should be 5/32 not 1/8. that is why it fell off the pull off. it should fit tight not just slip on.
Is that the carburetor from my 1969 Miller Meteor ambulance?
Here are some pictures I took yesterday. I found a red connector that was disconnected and melted. I connected it back but I am unsure of its function. Also found a severed cable to the black canister mounted to the firewall. Unsure where that goes too.
Found several wooden closepins in several lines, no idea what purpose that would serve, and finally took a fuel sample, which are the last 2 pictures, some debris in there and kinda greenish tint
I spent alot of time last night and this morning watching a carb video series and it helped familiarize me a bit with the parts. Going to check my accelerator pump tonight as I hear ethanol shrinks the rubber seal allowing gas to go past.
Some people put clothes pins on fuel lines as a method to control vapor lock. It is effective as rubbing salt on a rock to cure arthritis.
Let us know the condition of the accelerator pump.
That carb would would have been rebuilt with the proper material to resist the ETOH blend.
Is this the original carburetor that came with the car, or a rebuilt that they installed from an auto parts store, and they turned your original in for a core?
