thanks i think i will give it a try, i have used por15 and really dont like it lots have has some issues with it. Its funny but what i have tested and has held up great is old rustolem oil based rust metal primer and paint. I have had it on some stuff that has been outside for about 20 years and has held up way better then it should. thanks for the link and heads up.try some of this stuff http://www.hirschauto.com/prodinfo.asp?number=MIRHD-QT
I have never seen anything like it saves a lot of time and products and once it's on your done. you can have that entire back finished and ready to go back to gather in a couple hours. using less them a quart. we are testing it big time on the suburban. so far as a daily driver it's held up well. but a warning it's a floater is you spray it. takes overnight to dry and if you get it on you, you wear it for a week
today i dug real deep into the 58, i removed the tank, and pulled out the rear for us to do a rebuild and disc brake switch over to it if all goes well. No turning back now.
Rocky, you mentioned rear disc conversion. I dont know if you know or not that commercial chassis rear ends are NOT the same as a standard Cadillac, they have a 3/4 floating axle. You may want to read this thread for more info if not familiar with them, it may save alot of trouble later. http://www.professionalcarsociety.org/forums/showthread.php?t=8031&highlight=commercial+chassis+rear
And a Scotch Brite pad and lacquer thinner won't do it??
only if your get it now. surprising how fast it sets were you don't want it to. if a man were to spray it you better be out side away for anything else and in a full suit. let me know if you don't locate any I have a pair in the yard spotted that I need to cut some stuff off from. been waiting till spring and this 69 is past.
was that one Ex military to? looks like there kind of numbers on the firewall. or is that superiors sill number?
