Philip Scanio
PCS Member / Super Site Supporter
Jay,
As mentioned, pull the plug from the bottom of the door and let drain. Is your storage covered and out of the rain? If so, dry it out and don't worry. I had a 1981 Town Car with the same problem when it was new. I pulled the rubber plugs and left the door open on a slant after washing and solved the problem. I had a thought early this morning concerning boiling over. GM cars in the mid 1970's had a separate plastic holding tank for coolant expansion. When the car was turned, off the radiator fluid would expand into the plastic reservoir. Is this reservoir cracked? I never asked if the HOT warning light came on.
