Np Philip. Those are actually '79 hubcaps. The correct ones are on the drivers side. So I'll have to get those, and it needs 6 curtain rods.
Thanks Philip, no I didn't have the explanations for those numbers.
I'm leaning heavily toward just replacing the radiator with a new one, seems like it would be better in the long run. I had to end up using a car dolly to pull it to where it's being stored, since it sat for a week without someone transporting it like I thought they would. Since I'm no mechanic, I had no tools with me and didn't know to disconnect the drive shaft before pulling.
So 80 miles later, the good transmission might be shot. Not sure yet. I had no other option but to do what I did. I may've located a replacement one for $150 though, so if I need to get it I can. And since it was being pulled, one tire had to blow, but there was a spare behind the seat, so that worked out.
I can already see that I'm going to go through all the same stuff you guys have. At least there's a good support network here.
So 2 questions: What is the cure for the door holding water, and what should I use on the dash to protect it and keep it from cracking?
