remember the guy that said if your having trouble with something check the door pass threw first. here is a fine example of that. they removed the glass in this jeep but kept all the power lock and and window motor in. these wires should be hot but most likely the fuse is pulled out. still all the door has been doing is opening and closing. found the mystery set that have burnt in two under the front rug. my guess right now is dome light. we are in the process of removing any thing not needed from the doors and pulling any loose wiring out of the rig. with the top cut off, none of it is needed in this sight seeing limo. I did put the wing window and door glass back in with roll up regulator on the front doors.
