Jeremy D. Ledford
PCS Volunteer Chapter President
How do I remove and re-install an electric window motor with out chopping off a finger or shattering the drivers door glass on my 77 M-M? The window is in the up position and I have power at the switch and at the motor connection. But when I put power to the switch the window will not go down and makes no noise and the regulator is not in a bind. So I'm pretty sure the motor has shot craps! And a re-maned ain't cheap eather, I nearly fell outta my chair when I seen the price, $89.00!
I've done the old style crank type regulators but not a electric setup before. Any help will be helpful!
After reading the post and talking to Paul went out to the coach and did the rubber mallet thing that he said and that worked! Three good swift rapps and running the window up and down about 20 times got it working smooth again!!! And I still have four fingers, two thumbs and a intact peice of drivers door glass!!!!
THANKS!!!
