White House Beast #002?
Time to revue a decade's worth of white house beasts!
It's obvious to me there's still a bit of confusion as to which White House "Beast" is which, so I'm attaching General Motors photos from my archive that should give you all a solid, side-by-side visual comparison ...
The current generation of extra heavily-armored Presidential limos, visually defined by those extremely wide pillars flanking the windshield, debuted at Bush 43's first inaugural in 2001. Judging from available photos and TV footage showing the doors being held open for the President, the windows on these cars are six inches thick or therabouts, roughly double what was employed on Bill Clinton's 1993 generation Fleetwoods. Basic styling details are derived from the 2000 Cadillac DeVille that stayed current through the 2005 model year, though the wheel openings are much bigger and fillers were added in such places as under the headlights and between the taillights and trunk opening to account for the body's taller, wider dimensions versus stock DeVille sedans.
Bush 43's second inaugural parade in January, 2005 saw all of the 2001 style Presidential limousines updated with more-angular front and rear ends, "stacked" headlights, a grille-mounted Cadillac shield (versus the previous hood ornament) and a rear license plate housing relocated from the trunk lid to the bumper, all of which were inspired by the 2006-2011 model Cadillac DTS debuted in "civilian" form at the Chicago Auto Show a few weeks later. In common with the raised roofline and unsually-wide windshield pillars, aluminum wheels shod with high-profile, heavy-duty whitewall tires were a visual carryover. This is actually the generation of Presidential limo most often filmed or photographed in action during Obama's first term, as it evidently took a while for General Motors to finish decoy/backup duplicates to the 2009 style "Beast" debuted at his first inauguration.
The current generation "Beast," as I've just noted, officially entered service during Obama's first inauguration in January, 2009, and at least four were employed at the 2013 inaugural parade out of the nine units General Motors reportedly constructed. In distinct contrast to the whitewall tires, aluminum wheels and DeVille-DTS styling cues used on the Bush 43 limos, the "Obamabeasts" have blackwall tires, chrome-plated wheelcovers and Escalade-like headlamp clusters and side mirrors. The roofline retains the wide A-pillars and six-inch or thereabouts transparent side armor used since 2001, but the look has been made a little sleeker by adding a bright upper drip molding to unite the window openings. It should not surprise any of you to hear that I use the second image from the bottom as my desktop computer's screen saver!
The "last generation" of limos are sometimes still used, particularly for other dignitaries or trips where they have to be shipped. That may become less common if there are enough of the full-size Beasts.
I heard that, once retired, they are sent to the USSS training center for drivers' training. When they are done with that, it has been said they become "targets" for target practice (not sure that's true or not). Then they are scrapped. You won't be seeing older Presidential limos in museums anymore.
Funny that former presidents don't get them for their presidential library/museum,I watched a documentary on LBJ and on his return home board Air Force 1,on Inaugaration day,his last ride he had a crew go in and strip prize items to put in his library/museum much to the shock of all on board,
You have to wonder if some of the Beasts may have been rebuilt/freshened like the JFK and other Lincoln presidential limos were over the years. I think it was a piece by Gregg M. that told of this . The JFK limo in the Henry Ford Museum certainly been modified since November 1963, I think several times. Since the current cars are on medium duty truck chassis they'd certainly be capable of racking up a lot of miles. Somehow I doubt these cars accumulate many miles so they're certainly capable of serving over quite a few terms w/ some facelifts!
Saves
I know Reagan has a (well used) Cadillac Limo and SS Suburban at his Library and have heard that Clinton has one of the 1993's at his... not sure? MM
...Bush 43's second inaugural parade in January, 2005 saw all of the 2001 style Presidential limousines updated with more-angular front and rear ends, "stacked" headlights, a grille-mounted Cadillac shield (versus the previous hood ornament) and a rear license plate housing relocated from the trunk lid to the bumper...
As Gregg pointed out, clearly, that does happen.
I'll add what I know on this subject(mostly from wikipedia, lol):
No more presidents will be getting USSS limos for their libraries any more due to the fact(Steve Lichtman you are correct!:D)that they take old ones and use them for ballistics testing and research to make forthcoming vehicles more able to withstand attacks of varrying nature.
President Clinton was the last president to get a limo for his library and his 1993 Fleetwood also was the last limo to be a factory Cadillac chassis, all since have been specifically made for USSS service.
The current generation "Beast" is resistant to all kinds of threats and has its own sealed air system against biomedical attacks. Tires are called "Run Flats"(probably solid rubber). A blood bank of the presidents' blood type is carried in the trunk.
I'm thinking that it has a sealed air system for the engine as well in case of a gas attack of some sort, like if whatever gas it was would be enough to displace air in front of the car to make it shut off. May have air tanks with lines piped into the breather with a valve that would shut off outside air to just draw from the tanks so the car would keep running. Just a thought.
