Just what we need, some really excited cows!maybe not nuts but thinned with a little Bovine Excitement. one of the most powerful things on the face of the earth.
The left wheel chock has a 12.5 degree cut to the right, and the right wheel chock has a 12.5 degree cut to the left. You must accurately determine the diameter of the wheel with consideration of the proper inflation, so as to get the correct circumference referencing in relationship to the tire for the chock to properly fit. If you are having problems determining this, then check with the tire manufacture as to the rolling resistance of the tire in relationship to the ratio of the rear differential gears.
It is important to get them right, or you will be left out when it comes to the wheel chock judging event. This is particularly important if you are to be considered for any award of any type.
And I thought it was difficult to launch the Space Shuttle!
Richard
You guys are so mean to Richard... taking advantage of his "blonde roots" & picking on him! This one is the best rule to follow:
I'll explain it all to you in Flint buddy if you don't grasp it all by then...
