Looks like the water pump on the 54XL is leaking. I noticed green fluids on the garage floor and wetness on the pully below the pump. I pressurized the system using a pressure tester and it looks like the water is coming out of the front of the pump where the pully connects to the housing.
The best (maybe the only) solution is probably to replace the whole unit. It does not look like a complex job except for the fact that there is so much stuff in that engine bay that getting to the pump will be challenging.
Any thoughts or recommendations?
