you can do it just take you time and be careful trimming you don't have a lot to work with on that one.
Well, I feel bad the 184's got diced a little but I was just trying to help Richard out since I knew he had been looking for a couple of nice lights. I have about 20 of them and the skirts on all of mine are exactly the same height so that is what I hooked him up with. Richard was very nice to my friends and I who stayed at his hotel in New Smyrna Beach last weekend so I thought I would return the favor with the beacons and siren speakers. I'm sure he'll be able to make them work. They are in good shape and the motors are strong and quiet.
Got a little lost at the end of this post Richard. The "mini skirts" didn't work? I thought they would have. Even though they would certainly be low on the in board side. If you were able to locate another high skirt then you are now set for sure! Please post a picture when your done. It's going to look better than the singe 184H for sure![]()
I just set the 184's up the roof after removing the middle one to see how they look. I like it!. Still need to add the siren speakers after I locate angled mounts.
A long time ago I bought a pair of 184's pre-cut for a Lifeliner or Criterion, knowing that I'd have one some day. They are cut very nice. On my criterion, (back in '98) I did get a pair of 184s, but with the wrong base (all I could find); they had the siren speaker holes in them- forgive me....but I asked a body shop teacher how to cut them. He had me get some poster board and wrap it around the light to get the circumference. Tape it up so it won't move. Take it off the 184 and experiment with it (cutting a little at a time) until you get a good cut. At one point (outside) the skirt will be full length...but tapered the rest of the way around. If you screw up, start again. We took the "template" and traced it on the skirt with a sharpie and cut it slowly with tin snips. If the lights have no Federal ID (or any other tags), you can use the template on both. But if there is definately a front to each, then untape the template, turn it inside out and tape it together again. If you can understand all this you're very smart or lucky. I hope someone can give you an easier to understand solution!!!
Good luck
Kev
