finly after some messing around i got the poncho to start on it's own with out priming. guess you can only rebuild those pumps some many times. I had to go with a electric pump. took a little looking to find one rated at 4 to 5 1/4 lb. had to settle for a 5-6 lb pump it rttles more the I like but right now it a choice of a stack display of a running car. no pumps avable. I was hoping to run this one threw the old pump. I took the valves out of te fuel side so it would be straight threw. turned the electric pump one and has gas everywhere the pump would not seal at the seam. the raised porton has been worn off. guess you can only put a screw in pot medal so many times . sub post to be in the 50s starting Friday so we will try to swap cars this weekend. just got shades and hardwaire for the cabnet door left on this one. and clean up compound I may never get it all off this black.
