In the old days. sometimes it was glued to the block, but it shouldn't be necessary. If it is glued, it is a bear to get it off the next time. I have also seen a light film of oil put on one side of the gasket to allow it to move when torqueing the bolts. The most important is to torque the bolts in proper order, and to bring the torque up slowly, allowing the head to stretch. I would start at 30 PSI, and then work it up in 10 or 15 PSI increments. You are not being paid by the hour, so there is no rush of time. After the engine is running for a few hours, torque the bolts again to the manufacturers spec. Some people install the head bolts dry, and others install them with oil on the threads. Oiled threads will lessen the resistance and might lead to over torqueing the bolts. I was taught to install dry, but times change, and I don't know what the present beliefs are. In the "old" days, we would reuse the old bolts, and the head bolts on new cars are designed to stretch when installed, and not to be reused. I look forward to Peter Grave and Dan Scully weighing in on this matter, since they also have a lots of experience.
