Rocky Fluegge
Well this has been messing with me now for a few weeks. Here is what i have going on.
I pulled my 57 desoto out of the corner of the shop where it has been resting for too many years. Last time i ran it was about ten years ago.
well first try i put a battery in it and tried to start it nothing. I pulled the starter and tested it not good so i sent it out for a rebuild, they went tru it all replaced field coil brushes ect, and put a brand new selinoid on it. i put it in the car and still nothing.
I realizied the starter relay was also bad so i got a new one and replaced it. while i was at it i also did new battery cables and made a new wire going down to the selinoid.
Now when i hit the key it turns over and will not quit till i pull the battery cable off of the battery. I pulled the starter back out tested it on the floor with a battery charger. it worked the way it is suppose to. i took it back to the rebuild shop. They tested it and said it seemed fine. but they ordered another selinoid and put it on. They asked me how good was the battery. It was a used one but tested fine. So just to be sure i bought a new 800 cca battery put it in the car also.
Well put the starter back in the car. same problem if i hit the key and turn it over, it will keep turning over until i pull the cable off the battery. I also took a starter button and hooked it up to the starter relay same problem.
The only thing that i have not replace is the ignition switch?? any idea what is going on? At this stage of the game this thing is driving me flipping crazy.
Oh in case it matters the new starter relay i ground off the paint where it mounts so the ground is good, and i sanded the block where the starter and block comes together, and i also lubed up the starter gear also. i checked the ring gear it is in great shape no broken teeth and burs. Also the mopar starters cannot be shimmed out like the gm starters it fits into the block and two nut tighten it up not much movement.
Any answers or ideas, befor i roll this outside and start it on fire and watch it burn???:goodnight_smi:
