I received the below question about the "scales of Justice" icon located in the top right hand corner of each thread. I am going to answer this to the general membership, so all will know how this system works. It is a separate and independent ranking system. Please feel free to use this to show your pleasure or displeasure with the author of a post. This is an anonymous system and only you know what you have given. There is a place to give comments, but I still haven't found where you can read these comments. Leaving a comment is not a requirement. The "Thank You" at the bottom of the page is not connected to this ranking system in any way.
It refers to the "User Reputation system" and it is built into the software. Everyone starts off on a distinguished road, with reputation point level of 10 points and they can either move forward or backward in the reputation point system. This is all determined by the members of the forums. There are built in safeguards to keep any one person from being picked on. You will need to spread your reputation points around to at least 10 others before you can give a negative or positive point to the same person in another post. If you click on the "scale" in one of your posts, you can see your total points, however, points are given and taken away anonymously.
The terms that apply are posted below....
User is not well liked = has greater than 35 negative points
User can only hope to improve = 25 negative points
User has a little shameless behavior in the past = 10 negative points
User is an unknown quantity at this point = has 0 points
User is on a distinguished road = 10 positive points .... this is where everyone starts on day one of forum membership
User will become famous soon enough = 50 positive points
User has a spectacular aura about = 100 positive points
User is a jewel in the rough = 200 positive points
User is just really nice = 350 positive points
User is a glorious beacon of light = 450 positive points
User is a name known to all = 550 positive points
User is a splendid one to behold = 650 positive points
User has much to be proud of = 1000 positive points
User has a brilliant future = 1500 positive points
User has a reputation beyond repute = 2000 points
			xxxx said:"xxxx is an unknown quantity at this point"
What does that mean?
What does it mean when someone is listed as being on a "distinguished road?"
Thanks,
xxxx
