Matthew Taylor
PCS Route 66 Chapter President
Hard luck?
I guess I'm going to have to roll a car before I get a hard luck award! Thanks to Greg M. for nominating me, but if arriving a day behind and over $2600.00 spent on three different vehicles for a half-dozen mechanical failures isn't enough to get the award then I give up! On Sunday afternoon we spent 3 hours on the shoulder of I-70, and then another 3 hours in Greenville, IL getting new tires mounted on the trailer. The '72 Superior Pontiac ran hot the whole 1050 mile trip - so we didn't run the AC in order to keep it running. Tim Sibila changed out a water pump twice, a thermostat, a temperature gauge, radiator hose, and a fan clutch in order to address the temperature issue. I believe the car still has a head gasket issue but it ran at 220 the whole way back to Missouri - with the AC running. Tim also worked on the rear brakes on the '72. When he took off the driver's side drum a bunch of parts fell out! Now keep in mind I had already had all of these main issues checked out at two different shops in the month before we departed for Hudson. I also had the tires, and the brakes, checked on the trailer before I loaded the '67 Pontiac. The final straw was breaking the right rear leaf spring on the 2002 F350 while coming back from Swensons on Tuesday. So the Ford is at the dealership from 5pm Tuesday until Thursday - with the '67 on the trailer the whole time! You can't unload a car from a trailer without having it attached to a truck... The last issue diagnosed by Tim on the '72 was the excessive play in the rear axles, and the possibility of losing an axle on the trip home.
