the last 75 hood I replaced Kandy and I did it.  don't make a wrong move and you can do OK.  so here is what you do lets say you want to change hood hings.  a smart man working with his wife will do one side at a time. first place a place of thin plywood, chip board, thick  like 1/2 in cardboard over the glass tuck the edges under the fenders with the hood open. find you a stick long enough to hold the hood up in the front. the place the stick securely on the support and inside the lip of the hood go to other side of the hood from the stick remove the front two hood bolts. leaving the last on in place and like it was it was. have your helper hold the stick and the hood at the top so that it does not slide out. then you remove the back bolt and the front bolt. when you are ready loosen  center bolt enough that the hood will slide all the way down in the adjustment.  then you grab the hood a the rear with your out side hand right behind the hinge. from the top. when you remove the bolt with the other. you other hand will  slide it down the hinge till it is resting on the glass agent your protector.  at this point make sure you prop stick is good to go then remove the hinge out from under the  hood. put the new one back under it in the reverse order. except rear bolt first.  trade the stick do the other side and R&R that one. if your removing the hood one at a time slide the hood down the hinges agent the glass covering. prop stick in the center.  then you and your partner come around in front remove the prop stick  let the nose down  pivoting on the upper tip of the hinges. then walk around to the side one on each side, pick it up walk out front with it. one sets there side down and then helps lift it up on that edge of coarse you set it on these will place 2x4 you set agents the wall  sticking out. and before you lay it back a to the wall you have cover the paint with that blanket you brought out just for that.  going back one is the part that gets tricky. find you a set of longer bolt that will go in to the hood. place the hood on the high spots of the hinges and the noise down. from the back side. put the long bolts in to the the hood threw the top hole they don't have to be tight but make sure then are threw the cage nut. then come around front. and the two of you lift the hood till it slides in the adjustment hole. prop stick in place with ethe one had on the back of the hood put the rear bolt in first then go over the the other side put that rear bolt in and you have the hood captured. take your long bolts out put the remaining hood bolts in with the hand trick move to hood till it matches the marks on hinge for the rear bolt   tighten it go to the other side same thing and then crank  them all down. the most important thine is when you first lay it down do so slowly. seen a lot of headers and fenders scared up because some one got cocky and slammed the hood.  about a hr on and a hr back on. one a few spookie times
