Rear wheel studs or bolts
Fred Goerlitz
Northeast Chapter / PCS Life Member
My 76 Superior had a rear bolt break. Are these the same size as the front ones and does anyone have a source to get a set? (my shop is recommending changing all out on the one side) Thanks
Rear is unique to the commercial chassis. not available new unless you find some NOS ones. Have heard that some people have had them made but have not seen, the results of that. Have they determined why it broke? I have good used ones but would have to look to see how many I have on hand.
Apparently one was loose and broke. My shop wants to replace all 5.
They should be able to take one down and match it up at the parts store. NAPA should have them. If your rears use the spacer they will be longer then the front.
