Bill Leverett
PCS Member/Paramedic Supervisor
The rear door wouldn't open either when I got the car. I finally got it to open after having to take everything off the rear door...trim panel, access panel, handle attachment and medical cabinet. Lots of Liquid Wrench and attempts to move the latch with a screwdriver finally worked. The entire latch/lock mechanism was covered in a yellow waxy mess. Maybe this was from when the door interior panel was rustproofed? In any event, hard to tell if the latch had been repaired previously or if the modifications resulted in allof the brazing in the latch. One lower portion of the latch was had split causing the latch to overcenter. My local welding shop fixed that easy enough thankfully. Back together and working fine. Just need to recover the rear panel due to age. The cardboard & foam is falling apart.
