What siren and stretcher does it have?
...or will it have?
I believe I have a pair, I'll check when I get home from work in the morning. If the ones I'm thinking I have are these, they are painted, not chrome, and one was cut with a saw but both pieces are still there and could be repaired....The correct front tunnel lights for that car would be dual '61 Plymouth taillight assemblies on each side. Do you have a set of these, or should we keep an eye out?...
I believe Lloyd added a beacon as the one on there now is different from the one that was there in '96. That may explain extra holes. The curtains, signs, and demountable beacon don't necessarily mean it was a combination, as those could be on an ambulance as well....There is a single zipper in the front headliner for a demountable light. Upon removing the light today, I found there are 3 smaller holes for a permanent mounted light. I can also see evidence of the vehicle having originally having curtains and window signs on the rear door. There is also a C/B sign mount in the center of the rear side window. All this might add up to the car having originally being used as a combination car. I find no evidence of any hold downs for a skeleton rack, however, I have yet to totally unload the car and remove the rear carpet that protects the painted metal floor. It does have a floor mounted cot bar provisions...
Do you want a stretcher, like a Model 30?
Lloyd changed that beacon a couple times that I know of. When I first saw it in 2004 it had a blue lens and the skirt looked different to me (may have been the same though), he put this beacon on about a year and a half ago. Not sure why, I thought the other one looked lots better. Also the bullet lights have been on it since at least 2004.
Steve, are these the more-correct lights for the CB?I believe I have a pair, I'll check when I get home from work in the morning. If the ones I'm thinking I have are these, they are painted, not chrome, and one was cut with a saw but both pieces are still there and could be repaired...
C/B "torpedo lights":
Although not as common, these were used on some hightops, as well:
http://www.silverauctions.com/showroom_details.php?id=112
...or will it have?
Third time's a charm, I guess...?
...or will it have?
Some how, I missed your question...
The siren is a very small Sireno that is operated through the use of a solenoid. It is activated by the horn contacts, and there is a small toggle switch located on the left side of the dash that is marked horn - siren. This appears to be factory installed. I believe that the siren was installed by Lloyd, since the previous owner told me that there was no siren in it when he purchased the car from the funeral home. I found some dried flower pedals under the floor, so it appears that it must have been a flower car at one time ....
Kent Dorsey is sending me a non elevating cot for the car. Now all I have to do is find a cot bar.
Steve in your collection do you have a pictures of a Ferno #27. the only one I have is a new style mortuary cot.
