Dana Bennett
PCS Life Member
Yup.... MORE questions!!! Sorry!! Can't help it, my coach needs LOTS of help!!!
THIS time I am asking about the power steering gearbox. Just to refresh, I have a 1976 Superior Cadillac (with Hydro boost brakes if that matters?).
I need to have my coach pass NY State safety inspection and I'm pretty sure it will not pass as even after using a power steering sealer it is still leaking.
I am certain (how ever will double check again!) that the leak is coming from the top of the gearbox, a square plate with 4 bolts (all are tight) and a adjuster? in the middle (I do not know if this plate has a name or what it might be). I think it leaks more when I am turning, such as when I manuver back and forth to jocky my car over as far to one side of my girlfriends garage as possible.
I am guessing that it may be wiser to just replace this gearbox than to try to replace the leaking seal, am I right or am I wrong?? To repair the seal wouldn't the gearbox need to be removed anyway??
I am getting prices for the gearbox (remanufactured) between $130 and $170 or a seal kit between $30 and $75.
How hard is it to R&R the gearbox?? I am thinking it would probably be something I will let a shop do but not sure.
I am also assuming the gearbox is the same whether or not the car has a vaccuum power brake booster or Hydro-boost like mine??
Thanks for any input!! I'm kind of in a rush to get this done and have it pass NY inspection so I can drive it to the meet!!
Dana Bennett.
Dana Bennett.
...LOL!!!
