Peter Grave - Deceased - 1938 - 2022
Thanks Paul I will check into it
You are not correct on this. Antifreeze is usually (pardon the spelling) Ethyline Glycol with rust inhibitors and anti corosives for aluminum added. No water. Coolant is the same with water added. When I had my 87 Grand National other owners found using antifreeze with distilled water eliminated issues with the aluminum cooling system parts. I have used the antifreeze distilled water combination with good results on my keeper vehicles.
(spelling corrected)Antifreeze is usually (pardon the spelling) Ethylene Glycol with rust inhibitors and anti corrosives for aluminum added. No water. Coolant is the same with water added.
The terms "coolant" and "antifreeze" are used interchangeably, and they both mean the same thing. Please, lets not beat a dead horse...all of the cars and trucks I know of use a product that is both an antifreeze and a coolant, available in Full Strength Antifreeze/coolant (without water) or Pre-diluted Antifreeze/coolant. If you buy full strength, you add your own water. If you buy pre-diluted, you get the water mixed in for you already. Both contain rust inhibitors, water pump lubrication, and anti-corrosives.
Then I went looking for the Ph. of the premixed antifreeze / coolant, and the only thing that I was able to find, was a MSDS paper onWhat is the Ph. of distilled water? is it neutral or slightly acidic?
Absolutely pure water would be pH 7.0, but even distilled water is not pure. It still contains lots of ions. Totally de-ionized water would be pH 7.0.
Source(s): http://en.wikipedia.org/wiki/Deionized_w...
Deionized water will quickly acquire a pH when exposed to air. Carbon dioxide, present in the atmosphere, will dissolve in the water, introducing ions and giving an acidic pH of around 5.0. The limited buffering capacity of DI water will not inhibit the formation of carbonic acid H2CO3. Boiling the water will remove the carbon dioxide to restore the absence of a pH value. In practice, the indication from chemical indicators can give a value of usually between pH 5.0 and pH 9.0 depending on the indicator used.
Returning to the Internet for additional information, I found that .........
SECTION 9: PHYSICAL AND CHEMICAL PROPERTIESAPPEARANCE AND ODOR: Fluorescent yellow liquid with a characteristicCOEFFICIENT OF WATER/OIL DISTRIBUTION: Not determined
odor.
pH: 10.2 SPECIFIC GRAVITY: 1.06
BOILING POINT (F): 228 F VAPOR PRESSURE: Less than 0.1
FREEZING POINT (F): -34 F VAPOR DENSITY: Not determined
SOLUBILITY IN WATER: Complete EVAPORATION RATE: Not determined
PERCENT VOLATILE: None VISCOSITY: Not determine
Extensive testing has shown that a coolant pH below 8.3 pH is not acceptable for use in engines due to its corrosive nature. The correct pH value should be maintained between 9.5 - 10.0 pH. Below 9.0 pH it is advisable to flush the cooling system and refill with a new coolant solution.
Just got a call on my hearse. The Optispark is $748. With a few other things that need to be done, I'm in it $1375 so far.
Talking with the service manager has raised some red flags that make me wonder about their mechanics ability. We'll see.
Not really a hard job in some respects a lot easier than old stuff to work on. Nothing attached to the pump, belt easy on and off everthing pretty easy to get at.Hope it all works out for that kind of cash you should have O problems
Scrapping your 1994 Superior Cadillac Sovereign ???
Time to get it out of there I have never had an LT-1 with a burnt valve or bad piston. Plenty of blown rods and water pump optispark issues. If it will drive OK with a miss get it home. Then do the detective work. Remote bent push rod or rocker issue possible. Don't hit the scrap button yet. I have LT-1 engines in stock.
