final got the carb back for this one. we wont talk about some peoples business sense. but it's back. new bushing and complete kit in it. you find a man that can work on one of these and do good you have to hang with him.
we cleaned things up and got it back on and once we plugged the coil wire back in it poped right off. I got to looking at the old gasket and I can see were it was leaking inside. lot of rust in the inside of the passage way and carbon going into the primary. she just runs like a car that needs driven so we'll drive it. the big oops was the superior rear heater valve has failed to keep the green gooie stuff in. so we swapped that out and so far the spare one from the left over parts bucket is holding.
did learn some stuff . rather then fight the steel lines start the fuel line before you put the carb in place and I'll pass on when doing some thing with mutable gaskets a couple of #2 Phillips screw driver will help to align things so you can get a bolt in with out messing up the you can't get anymore gasket.
