Need help determining if compatible...
Kent Dorsey
PCS Member / Funeral Director
A funeral director I know has a 96 M-M hearse that needs the chrome fender skirt part, we have located a 94 Superior chrome fender skirt, and we have no idea if compatible, and can't find anyone else that knows... help...
Daniel Scully
The skirts' are all the same even from a passenger car. They way they attach is the problem . It is a stock skirt modified and usually has 2 studs and nuts instead of the of the levers on a stock skirt. Your pic looks like it has this setup. Get a inside pic of the replacement skirt to see if it has the 2 studs. You can use a stock skirt but it will have to be modified to work on the upper attaching points.
Daniel Scully
Skirt
This is a stock skirt. On a CC they remove the lever and replace the upper locating studs with threaded studs for a nut or wing nut.
I have several off of Fleetwood sedans, if you need one. As Dan mentioned, it would have to be modified.
