Peter Grave - Deceased - 1938 - 2022
Make it right???? NO its vastly better as far as being reliable and fun to drive. Enjoy it and keep the hood closed.
how about some more pictures of the engine compartment, and the inside if you don't mind.
Herb
Oh, but that is definitely NOT velour! That is the original Mohair! New mohair sells for $300 and up per yard. There is a clear difference between cheap velour and real Mohair.
John,
For a total of $300, I will sell you enough REAL, matching Mohair to do your rear floor and any other areas that needs replacing in your rear compartment.
Great shot of the engine looks like it was made for it. Since dash is not stock (makes me sad scrapped a 49 Cad. sedan last year left dash in) why not add AC and be real comfy in the summer? Chevy tilt column is a nice touch again makes Coach much nicer to drive. 49 Caddy wheel and column where not positioned user friendly.
As my dad said when I bought my first 56 Packard with AC " What the H*** is the matter with you just uses more gas open the vents and go". You are right the original cluster would never work now.
Actually you could do a budget AC installation by using 350 GM brackets and compressor with a 60s aftermarket underdash AC unit and condenser. Then just have the lines made. Those AC units show up at flea markets and go begging
Guess you are right. My recently returned after 48 years 56 Packard Caribbean Hardtop had vintage air added by the last owner in Florida. He told me he was very pleased with it. I have no been well enough to try the AC this spring so I can offer no personal opinion on its performance. I am however not pleased with the way the compressor vibrates on its mounting with the motor running only. I will have to investigate this when doing better. The under dash unit is indeed more compact. My thing with AC is since most events are in the summer its nice to arrive cool not sweated up.
