5500 each for the cars 3000 for the trailer, probity 1000 lb tong wight before you loaded yourself, your baggage and the tool box. then fill the truck up with 8lb a gal fuel. OK there rough estimates but all close. the truck will handle it fine but you have gobbled up your extra safety factor. as long as you know this and can adjust your driving to compensate you will do OK. I have pulled more just over the margin then I ever have into the safety zone. the key is having tires on the truck that will handle the load and adjust your driving habits for what your carrying. but never try to fool yourself into it's not over loaded
Waaaayyy of on weights there Ed.
Assumptions on this type of thing within a hobby field is not just an Uh Oh, my bad on being off. It is a matter of life safety and also personal property safety. Moving coaches is 20 times worse than hooking up to a standard car or truck.
Here are the "accurate" weights +/- a few pounds. When it comes to moving these cars, everyone "has to" be safe and know full well that a heavy coach can definitely gain control of your towing setup and make for a nasty day.
Hearses - 1940's - 1950's = 4900lbs - 5600lbs
Hearses - 1960's - 1970's = 5400lbs - 6200lbs (depending on options)
Low top ambulances follow the same weights as hearses +300lbs for cabinetry
Hightop Ambulances 1950's = 6600lbs - 7200lbs S&S's are the heavier bodies
Hightop Ambulances 1960 - 1966 = 7400lbs - 8100lbs
Hightop Ambulances 1967 - 1976 = 7700lbs - 8400lbs
22' - 24' Heavy steel car trailers weigh between 1800lbs - 2200lbs
50' Gooseneck car haulers 4900lbs - 5700lbs
It is always better "to know" semi accurate weights when towing potentially heavy cars. This always becomes a bigger factor when tow weights are known to become top heavy in turns.
My last trip saw some good weight and stability. THE KEY TO A GOOD TRIP IS WEIGHT POSITIONING. Make your trailer axles take the brunt of all weight, keep your tongue weight to a minimum.
My last run stats are as follows with 2 Hightops.
Truck - 6778 lbs
Trailer - 5600 lbs
Car load X 2 - 7811 lbs ea.
Misc tools + 2 people 400 lbs
TOTAL WEIGHT ON PLATE = 28400 lbs
I would never advise anyone to do this with a standard truck, I use a custom power built pull truck to handle the weights.
