It looks like I may have no choice but to place a special order to get the laminate I need to replace the interior of my 54XL. The issue is that the laminate manufacturers still print White Ash laminate, but I have not found one yet that prints it in gloss finish. I can get matt finish no problem, but not gloss. I guess gloss finish for kitchens are passé.
Formica, which is the actual manufacturer Superior used for the laminate has a minimum order of 8 sheets, which is probably about double of what I need. I will reach out to the other manufacturers such as Wilsonart, Arborite or any other I can find to see what options I have. If anyone has any ideas, please drop me a line.
In the meantime I will measure exactly each components and compose exact drawings to calculate as accurately as possible the number of sheets I need based on the cutting pattern that will produce the least waist.
I am using Sketchup to draw each components. Once I am done I will be able to "blow-up" the components and overlap them on virtual sheets of laminate.
