Peter Grave - Deceased - 1938 - 2022
Looks good same compressor as my Packard has. Bracket should be an easy make up. Like Ed says NEW!!! O rings everywhere save the heartbreaks of leaks. Watch how you route hoses keep them away from hot things. Sleeves over hoses where they get heat makes system work better. I would skip the electric fans that rig was designed for AC electric fans are redundant use only if you have problems. I do not think you will none of my 70s ever overheated in the summer with AC on. Good luck with the job. Oh yeah DO NOT open receiver drier box and pull caps off till you are ready to install you don't need Fla. humidity in it.
