HELP needed ASAP-Bearing support
Can you contact them to see if it is the bearing or the support piece the bearing is mounted in please. The support piece is metal and mounted to the frame crossmember. There is a rubber mount in the middle to which the carrier bearing is mounted into it.
We're making another work but now curious we're comparing apples to apples.
TKS
you are correct, it is the bearing only. sorry it was not what you needed. thanks kenn
Ok boys here's the deal. My guy installed this bearing support (last picture) from a GM van and we'll see how it works. Other pictures to show my support bearing how it is supposed to look and the damage to it.
I highly suggest if you run across one better buy it.
it will work good. now get two. the live liner has the same possibility for trouble. and 10 years from now when you need to do this again that set up will be obsolete and no longer around. or send that old rubber and housing out to have it recast there is nothing wrong with the mount. the cast rubber that was in it is torn out. that shinny spot is nothing.
