strange set up and now thats it off things are starting to work. here is a pictures of the headlight relay and the instruction. the terminal you took the #12 wire off from should have power to it. the one you lit with the test light should have power when the light switch is on. but since we do not know what the relay is powering or when. it a matter of tracing the wires out. feel sorry for you 41 out there is cold you can't get away from. we were that warm today and I cleared off the drive in shirt sleeves in the sunshine.
now this is not saying that the relay is used for the propose it was designed on your car. but it would have to be wired the same to get it to work. trace the load wire out and find were it goes.
