I will need to replace the gaskets on the front sign, the antenna and the shore line receptacle.
The front sign is currently made out of cork and is sticking out a little. Must be collecting moisture from the Atlantic air after being in the dry Alberta climate for the last decade.
Do you recommend I use a cork gasket again for the front sign or should I go for a rubber gasket? The rubber gasket I would use I'd from an old tire tube.
I plan to use rubber gaskets for the antenna and the shore line receptacle.
