Just so that I forget about the turn signal for a while, the car decided to stall and not to start again. As the car was running idle in the driveway while I was testing the signal lights the engine died. It sounded like if it ran out of gas.
I checked the gas gauge, it was between Empty and ¼. It is possible that the gas gauge could be faulty or maybe it is off a little and I ran out of gas. Since I just filled a jerrycan to use for the lawnmower, I promptly emptied it in the car, approximately 4 US gallons. I tried to start the car again, no go. Squirted gas in the carburetor for a couple of tries, no go.
I thought it could be the fuel filter, so I went to Canadian Tire and got a couple of them. Once I got back home and started the process of removing the filter, I quickly found out that none of the 1-inch wrenches would fit in the tight space required to remove the filter, so after visiting NAPA, both Canadian Tires and Princess Auto, without success, I came back home, got one of my old 1-inch wrenches and modified it a little with the angle grinder and voila, I now have the perfect wrench for the job. (See picture attached).
Since I was there, I took the occasion to replace some of the brittle vacuum hoses that were in the way.
Replacing the filter was a straightforward job. I then put everything back together and went through the proper starting sequence and the car still did not start. Squirted some gas in the carburetor, turned the key and it started immediately only to stall 5 seconds later.
I know that I have air and fire, definitively missing the fuel component. A visual inspection reveals nothing lose or leaking.
Would my next step be to change the gas pump.....thoughts, suggestions?
