John Dorgan - Deceased - 1938 - 2012
March 05,1938 - May 13, 2012
I have been asked to outline the differences between the Federal rotating beacons and will endeavor to do so here.
The model 17, which dates to 1948 has two bulbs and rotates on a horizontal plane.
The model 173 has three bulbs and rotates on a horizontal plane.
The model 174 or Super Beacon Ray has four bulbs and oscillates about 95 degrees.
The model 175 has four bulbs, and a clear dome. It rotates on a horizontal plane. The two red bulbs were normally level while the cler bulbs were angled up and down 10 and 35 degrees.
The NYPD version of the 175 was basically the same, but the angled bulbs were angled up and down 10 degrees each. It also used amber as well as red and clear bulbs.
The model 176 has four bulbs on a horizontal plane.
In addition, all of these were available with an "A" base which was an enclosed base made to be mounted on a 1" pipe.
The Califonia special had a PAR 46 fixed red light attached to a higher skirt.
The "H" suffix denotes a high skirt. These were avalable all the way up to
11". in height.
The NYPD model 175 used a 7.5" height skirt to be seen over the Federal P-660, Pulsator siren which was placed in front of it.
Domes came standard in acrylic, lexan and glass on special order. The original patent calls for a poycarbonate dome. Colors available over the years were; red, blue, clear, green, amber, and magenta (Purple).
The rarest was the 175P which can be seen in the lead in to the Hawaii 5-0 TV series. This had a small "cruise" light located in the top which was on at all times that the vehicle was in operation.
There was also a difference in the dome diameter caused by the fact that the four bulb beacons would not fit into the smaller earlier 17 and 173 domes. The top opening of the skirt was also opened from 7 3/4" to 8 1/8" to accomodate these larger domes. I hope that this helps. John Dorgan
11". in height.
