Brendan Martin
Last week I had a gasket overhaul, and timing chain with cam gear replaced. The car had several oil leaks, we replaced the oil pan gasket, front timing cover gasket, oil pump, and water pump gaskets, and installed a new timing chain, and cam gear. The engine block and radiator were flushed, and new coolant was added. I also had the front engine seal, and rear main seal replaced. My mechanic used this as a filler project in between other jobs, and also degreased and painted all the parts he removed. After driving to the garage and letting it get cold I checked a day later, and no drips. As for now the mechanical issues are resolved, now time for bodywork, paint, chrome and interior.
