Tom Hoczyk
PCS Past President
Fans
I have been doing some serious investigating during the last year, regarding installing a fan in my '60 Eureka, which has factory a/c. In my case, the engine doesn't tend to run hot, but I'd want the fan to augment the air movement past the a/c condenser in city traffic, or parades, or other slow moving circumstances. I would set it up with a heavy duty toggle switch and relay, so I can choose when to run it.
I'd like to recommend that, with hot summer months approaching, if your a/c works well while on the open road (lots of air passing over the condenser), but warms up while creeping through traffic, you shut OFF your a/c completely, as the pressures in the system are getting very high and could possibly rupture a weak hose or a safety blow-off on the old GM A6 compressors (1962-1978 or so). Some A6 and R4 compressors have high pressure switches built into them that automatically open the circuit when pressures are high, but you really have to know your system, compressors, and switch color codes to know which switch you have (if any). Tom
