Jeremy D. Ledford
PCS Volunteer Chapter President
Heres a link to the tires that I'm using, http://www.deantires.com/html/products/tires_passenger.aspx?page=dean_tires_passenger_alpha_365
			I put Runway 75's on a few cars and had good luck with them. They come in 215/225 or 235. The white wall is 1.25, not as wide as the 1.6 but they are half the price too. I also have a set of American Classics on my 83 S&S, they look and ride good. Never had a problem with any of them.
I need a few sets of new tires for my hearses. Both my 1962's could use new tires. One still has the bias ply tires it came with. The other has radials and rides much nicer. Safer over bumps in the road for sure.
It seams harder to find P235/75/R15 radial tires with a 1.6" whitewall these days. Easier to find a 2-3" whitewall but are not correct for a '60s Cadillac.
Firestone use to make an extra load tire and so did Michelin. Both have discontinued them.
I have found Lucas Tires in Springfield OH and Coker Tire both sell the
American Classic for 134.00 each.
I was wondering if anyone has these on their hearse or has any experience with them.
If you have any recommendations for tires, please let me know.
All info regarding tires would be helpful.
Thanks !
Darren
It is getting hard to find whitewall tires (or even blackwall, non-truck tires) in the sizes typical for larger cars which were common in the 1970s. Lots of the Rolls-Royce Silver Shadow owners are recommending the Khumo and they seem to work out, and they are not expensive at all. The Shadow is a heavy car and the tire is rated high enough for the weight. Tires with heavier construction seem to last longer and make a heavy car handle csome better (handling? my car did not come with that...)
There is a Hankook whitewall as well, and I have seen some Firestones and some of those you have already mentioned. The manufacturers have specs available on line which list the load rating and overall diameter for each size.
Alas, it looks like soon we will have to buy the often expensive collector-car tires to avoid using truck tires.
As for cleaning whitewalls, you can use Scotchbrite or fine wet-dry sandpaper to really get them glowing. The sun messes up the outer layer and yellows it, and the abrasive removes this.
I thought I'd revisit this old thread as I now have two years worth of experience with the Runway Enduro tires mentioned here. Overall, I'm going to have to give them a grade of D- .
I have no complaints about the tire's abilities. They hold the weight of a hearse well, and even though the car they're on has only been to and from car events over the past two years, there's no noticeable wear on them.
But the whitewalls over time are horrible! And let's be honest, the only reason someone would buy these tires are for the whitewall. When the tires were newly installed on my car, I was beyond pleased. I thought I had found a tire for my entire fleet. Now I'm so very glad I didn't go hog wild and actually do that.
Within six months the whitewalls started browning, and only serious scrubbing with abrasives got them white again. But then it would only be a matter of a couple weeks before they were brown again. Now, after two years, they are permanently brown. I have given up trying to get them white any more. Its a losing battle. It seems to be an internal issue with the tire itself between the black and the white, because they really never get dirty just going to car shows, and no matter how much time I spend, what I use, or how much scrubbing, they are just permanently stained brown now.
I almost can't wait until I wear them out so I can get something else, but since I've only put about 1000 miles on them in two years, that's going to be a long wait. I wonder if anyone still makes whitewall paint.
I gather that cooper still makes one. the last time I was at tires plus they had a 235x15 with a white wall about that size for 90 bucks carry out. I checked the side and they were good for 2045 at 35 psi. the would be heavy enough for most of the cars
