How many of us had to sit in dirty sub-standard ambulance stations between runs over the years?
The attached photo is a house that served as an ambulance station and dog grooming shop. The wiring system had the well and the window air conditioner on the same circuit, so if you flushed the toilet in hot weather, it blew the breaker. No cable television, so we had tin foil creatively draped on a rabbit ears type of antenna on top of the set. And the set was an old black and white that was liberated from some hospital. The garage door was manually operated and did not lock, so we just locked the door between the garage and the quarters. The quarters itself was the small area behind the ambulance in the photo. The open door in the garage lead into the quarters. The whole rest of the house was the dog grooming shop. You backed the ambulance in until the rear bumper touched the back wall and you had just enough room to close the garage door. This station was in the Minneapolis suburb of Minnetonka in the area referred to as 7-Hi.
Later on, I worked for another service in the twin cities that had an ambulance station inside a wholesale florist warehouse. The ambulance parked in a space along the loading dock inside the warehouse, and the quarters was in a plywood room that was thrown together up on the dock. All day long semi's delivered new stock, and smaller delivery trucks took flowers and related material to retail flower shops. We often had to wait for trucks to move in order to enter the garage or to leave on calls. No code enforcement in those days. The building had no fire sprinklers and there were no smoke detectors in the building. They marked out a path on the floor with tape so we could use the restrooms after hours. As long as we stayed inside the marked pathway, we did not set off the security alarms.
