I got a price for Richard of $300 for a 30 pound cylinder delivered directly to him in Florida, from a licensed R12 recycling facility.
Hi Richard! I have substantial automotive air conditioning experience and having read most of the posts here, everyone is making good points. Perhaps the three I'd like to emphasize are these:
1) Paul is correct. The physical characteristics of R-134a are that it requires a larger condenser to give equal condensing to the R-12 condenser. (The condenser takes the high-pressure, high-temperature refrigerant gas from the compressor and removes heat to change the refrigerant back to a liquid.)
Along the same lines, the molecule of R-134a is a smaller molecule than R-12. As such, special refrigerant hoses are necessary to keep the molecule from seeping out through the hose material. Typically, the hoses are made of Parflex.... more of a plastic than a rubber.
2) Our cars from that period are notorious leakers of air around doors, etc. Any leaks of incoming warm air will only work against the attempts of the a/c system to cool. Seal those leaks!
3) I have a '76 S&S hearse, and the a/c of the '75 would be the same. There are times that GM, much like Ford with their "better ideas" doesn't do the consumer any favors. To this day, even on modern cars, I deplore automatic air conditioning. Give me manual a/c of '63 and older ANY day. Most of the guts controlling the '75 system are located below the glove box and need to be set up correctly in order to give satisfactory results. Robinair even manufactured a diagnostic device to test vacuum and electronics of our cars ('74-'76). I've seen these on ebay, so keep an eye out. In short, the programmer senses interior temperature and tells a transducer to move a control arm in or out to control a damper, warmer-colder. It is possible that at max-cold setting, the arm, which is adjustable, is not fully extended (or retracted, I don't remember which) to give max-cooling. If the system is in otherwise good condition (full of refrigerant, etc) you can get on your knees on the passenger side, open the panel beneath the glove box, and see if the control arm is adjusted fully out (or in).
One last comment about the compressor. The GM A-6 compressor used on this car is a workhorse compressor used since 1962 and is a GREAT compressor, my personal favorite. They have 6 cylinders, great compression, an oil sump to keep the components lubricated, and are relatively inexpensive and still easily available. I would NEVER consider changing to an "updated" style compressor in my '76. I hope this helps. Tom
www.bippusautostorage.com/cars
Tell me more about the pusher fan and how that is set up.
More in line with what a 30 pound container is going for.
http://cgi.ebay.com/ebaymotors/FORANE-REFRIGERANT-PURE-VIRGIN-R-12-AC-30-POUNDS-_W0QQcmdZViewItemQQhashZitem35aa4a9d7fQQitemZ230490283391QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Virgin always cost more!! :badbad:[/SIZE]
