99 cadillac front bearings
Nancy Coburn
New member
Hey all, i'm hoping for some info about front bearings for my hearse. He is a 1999 Cadillac hearse, on the B9Q chassis. He needs a front bearing package, the heavy duty 6 bolt one and nobody seems to be able to find the right one. It is discontinued according to Cadillac, but there must be something to fit him? Any help would be appreciated
Administrator
Staff member
If you have a Cadillac part number, I might be able to help with locating one for you. I don't know how the bearing is assembled, however, there is a possibility that the bearing itself could be pressed out of the housing and replaced. That is a possibility that you could explore with your mechanic. Not being familiar with the 1999 models, is this a front or rear wheel drive?
Peter Grave
There is a Company in Colmar Pa. Bearings and Drives Solutions. I have used them for 35 years and they can come through with weird bearings. web site http://www.bds-usa.net/. Go there for more info they are now national.
Administrator
Staff member
The price might not be what you wanted to hear, however, I did locate the part for you using your part number.
Shops Where You Can Buy This GM 25696347 Hub
$684.81 Buy GM Parts Headquarters
Portland, OR
$736.85 Buy GM Parts Giant
Northridge, CA
$796.86 Buy Online GM Parts
Schaumburg, IL
http://oemcats.com/oem-parts/256963...ine General Motors,1 item in retail packaging.
This is a hub, front wheel (with wheel speed sensor) (acdelco #fw175), for Cadillac automobiles. It fits for Cadillac Deville, Deville touring, Hearse, High luxury, Limousine, Seville, Eldorado, Eldorado touring, Concours, and D'elegance for the U.S. from 1998 to 1999. It's a genuine General Motors part with an OEM part number 25696347, and corresponding ACDelco part number FW175.
This hub has dimensions 7.40 in × 9.50 in × 7.40 in, it has a weight of 12.89 pounds, usually, it comes in a set of 1 item in retail packaging. Bulk packaging option for wholesale buyers is a pallet of 75 units (UPC-A: 70021625936214).
This part has a standard 12 months GM warranty on replacement parts, and it may be returned to a dealer even if the packaging has been opened.
In spite of higher price of genuine parts buying this hub will be a smart decision because you will be absolutely sure that it will serve you longer and will provide maximum safety and performance for your car.
This hub 100% fits for General Motors cars. It's made of top quality materials, it has passed not only all manufacturer's tests but also General Motors quality control and has to endure rough road conditions over a long time.
GM 25696347 Hub Dimensions and Packaging Options
Retail Packaging
This hub comes in retail packaging with dimensions of 9.50 in × 7.40 in × 7.40 in and weight of 12.89 pounds.
Dimensions of GM 25696347 Hub
7.40 in.9.50 in.7.40 in.
Weight of GM 25696347 Hub
12.89 pounds
25696347
021625936215
Pallet Packaging
Pallet Packaging GM 25696347 Hub
Pallet packaging contains 75 units in retail packaging and has a UPCA code 70021625936214.
Portland, OR
Northridge, CA
Schaumburg, IL
Administrator
Staff member
On a whim, I put " 25696347 hub " into the search engine at www.ebay.com, and it came back with 29 results for that part number, starting at $50.89 to $83.99, and some sellers offering free shipping. It is up to you to determine if this is the correct part for your car. Many sellers offer free return shipping, which should make it easier for you to compare it to your cars original part.
This one seller offers free shipping, free returns, and a lifetime guarantee. The price is $56.99 You can't beat this deal with a stick! Click here
NJ Dorsey
Registered User
