'93-'96 S&S Victoria Drapes
Yes - although matching Velcro may need tweaked in your Medalist. Height differences come into play above drip rail. That isn't to say they were all mounted at same level however from Accubuilt. Same drapes were also used on Superior & Eureka models. I have first hand experience swapping colors out between '93-'96 non-CC and CC glass coaches.
Thanks for the info. Haha, I wish the Medalist was mine. A local FH has it. The reason I asked is because I thought the rear door/window was shorter on a Victoria than a Medalist.
Having not owned a Medalist, that may true. If so, the negligible difference can be easily accommodated by moving mounting Velcro. Have also found prolonged sun exposure can cause shrinkage to occur as well. Not noticeable really until no longer being able to match those Velcro strips up.
