That same car was on craigslist last week for $1500.
Thank you for the intel. What a louse?!
Dr. Studer needs to finish one of his projects, not get more...![]()
but wait, who needs a photo when any body man can fix that flat panel with ease. of course that is after he removes the headliner the sound deadener and any padding between the cross supports and the roof you are going to weld across. then of course add the price of a new headliner as the original one is weathered and brittle.
but running and drivable helps a lot makes you want to spend the money to get it and fix it. knowing the lights and siren work is a plus also. the good shots of the interior show you only in need of clean up there. that helps. might need new flooring though.
but other then the top box missing it looks to be all there one more plus. if he has located the curved tempered glass another good deal.
I would say if you could get the car under 5 it would be OK Keven's with the body work done would be a better buy.
Apparently, $3900 is the magic number. He has it listed on Craigs List for that amount.
........... that set of crosses in someones garage will be a shocker to replace.
