66 s&s restoration
pretty rough but definitely worth saving
its going to take alot of work
It was time to give her a new life at 100000
battery box,floors, and roof
roof, and rear door
lt quarter
rt quarter inner
rt rear door
rt front door was shot
rt fender salvageable lt fender replaced along with the hood
finally paint and new bumper and grille
Great work you have done on that car, in such a short amount of time. What did you use for paint? Looks like single stage... :thumbsup:
Finished in hot rod black. Total time was from April 16th thru July 6th. Working on it at least 40 hours a week
I have learned that many times the rear door glass is from something else. I suggest that you measure diagonally from upper corner to lower corner, then the width top and bottom, and finally, the height at the end and in the middle. Carry a cloth tape measure with you whenever you are out along with the measurements, and you have a good chance of finding another car that has that glass. Once you know if the glass was used by another commercial chassis builder, it will give you a better chance of finding it. Presently, you have limited your search for S & S, however, Miller Meteor or Superior might have also used that rear glass. Also post the measurements here, and I will check my 1969 Miller Meteor glass to see if it is the same.
Didn't S&S exclusively use that rear door glass in the '60s and '70s (possibly even later) that had a "bend" in the center that lined up with the vertical seam in the rear door? The attached photo is of a '72, but same configuration.
Glass
That is S&S only. I have a set of doors from a 72 .I believe the rear door glass is the same 65-76 I really would like to sell the doors as a set , good glass and doors and hinges on all doors. $600 for all 5 doors . with out the belt line trim. If the door glass would work maybe someone else needs the other doors your way?
